Cathedral Ceiling, Cellulose, Foam Board
![](https://secure.gravatar.com/avatar/891c9112eb62bfa864a298fc5363cf22?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
I am planning on building a small house that will have a cathedral ceiling. General details are that it will be approximately 14′ wide, and around 25′ long. I am planning on having the roof with a single slope, like a shed roof. I am trying to achieve around a R-48 for the roof. Climate zone 6B. Initially, I was considering 14″ tall I-beam style joists, 24″ OC. I was planning on filling these with fiberglass bat insulation (R38). I would plan on having an insulation baffle, using the shoulder of the I-Joist to create a 1-1/4″ ventilation space below the roof decking. Below the insulation would be 2″ foam panels (R10), 1×3 spacers, the 1/2″ drywall.
After costing out the insulation, I started to consider sprayed in cellulose insulation. I think if I upsize the rafters to 16″ thick, I will have room for 14″ of cellulose insulation, which gets the R-value up to R49 (assuming R3.5/inch). This then eliminates the need for the 2″ foam board insulation, and the sleepers for attaching the drywall, as now it can be attached directly to the I-joist rafters. This option should be less costly for materials. I assume by eliminating the foam board, there will be some thermal bridging. I am not sure how detrimental that will be to the overall R-factor.
Has anyone else built a ceiling/roof this way? Any recommendations, or gotchas to be worried about?
