Warm-Climate Cathedral Ceiling Assembly- Any issues with these materials/lack of vapor barrier?
![](https://secure.gravatar.com/avatar/c8416990fdd7865bdbcb0b4fcd68814e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Does anyone see longevity issues the following material/build choice? Located in San Diego.
-From inside to outside.
-Joists are 2×10.
-Primed/painted T&G boards 5/8″ drywall (primed) for fire barrier. AIR SEALED.
-23/32 cdx plywood-AIR SEALED(was free- using as easy nailing surface for T&G)
-R30 Rockwool (7.25″) slightly compressed to 6.75″ to make fit in cavity
-1″ GPS R4.0 unfaced foam board with perm rating of 3.0, fully air sealed. Used to build on-site insulation baffles, with 1.5″ air gap between this baffle and bottom of roof assembly (old tar paper/shingle setup)
This has been a labor intensive setup and I just want to make sure I didn’t overlook any steps before drywalling and starting the finishing process. If my research serves me correctly, there is no need for a vapor barrier given my mild climate (San Diego), meticulously air sealed drywall AND plywood layer, and semi permeable insulation baffles (Perm 3.0). If anything, it sounds like a vapor barrier could be harmful as my currently assembly can dry both to the inside and outside, if needed. Correct? I’d rather spend the time/money to do it right the first time but after reading dozens of articles, thats not always a crystal clear path.
Open to ideas/suggestions
Thanks!
Buildingfun,
That sounds like a good roof assembly for where you are. My only question is whether you need the drywall. Our code would accept the T&G or plywood as a compliant ceiling for fire spread.
Ooooh! That would be neat if I could eliminate drywall layer. Will research.
THANK YOU!
oops. duplicate
