cantilever steps
![](https://secure.gravatar.com/avatar/bfaae7f69bbfeba6c08516f9a880bc24?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
I want to move my steps- inside. I want to have cantilever steps, but can’t find any places that make them. As this is residential, it seems to make it even harder to find someone.
Also, I have 6 inch solid concrete exterior walls- will it be safe to attach cantilevers to the wall- I wouldn’t think I would use more than a 2-3 inch ‘bolt’ or other attachment to the wall- would it disrupt the integrity of the wall. I live in an earthberm home and that wall is covered with dirt.
Thanks
Hi Deb - I am having trouble envisioning what you mean by moving your steps inside. Whatever you end up doing, you will need a design that meets with local building code requirements. I would bet that with a 6-inch concrete wall you will need to use through-bolts and some sort of plate or washer to spread the load around each through-bolt. Hope this helps but feel free to come back and hone your question a bit.
Can you snap a photo and send it in? ([email protected])
We'll have a peek and see what we come up with.
