Can you place Hard-plank over T-1-11?
![](https://secure.gravatar.com/avatar/763146352f3c6c5ce487d4766b44856a?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
calvins2
| Posted in Building Code Questions on
Felt or Tyvek?
Ray,
I'm assuming that you are talking about HardiPlank, a brand of fiber-cement lap siding.
Yes, you can install HardiPlank on top of T-111, as long as the T-111 is not rotten and is well fastened to the wall framing.
Between the T-111 and the HardiPlank, you will want to install a water-resistive barrier (WRB) like asphalt felt or Tyvek. Either product will work, although taped Tyvek (or another brand of plastic housewrap with taped seams) will do a better job of reducing air leakage than asphalt felt. For more information on WRBs, see All About Water-Resistive Barriers.
