Can unfaced polyiso be used for radiant heat systems?
![](https://secure.gravatar.com/avatar/7854b0fb3e41c23f734dc58ed8ae34c4?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I have radiant tubing installed between floor joists. I’ve placed a foil reflective sheet beneath the tubing and though faced fiberglass insulation is recommended to be placed beneath the foil sheet, I want to use un-faced polyiso boards 3″ thick instead. The boards will be exposed to a heated, block wall, basement that is reasonably dry.
I would appreciate your comments.
Regards, JTO
It's fine to use polyiso under the radiat floor, but note that the shorter 3" path through the wood has half the R-value as the 6" path you would have with R19 fiberglass. Either would be sufficient for zone isolation between the first floor & basement though (even R11 batts are "good enough".)
If the tubing is tight to the subfloor or in aluminum heat spreaders there's almost zero benefit to the foil though.
