Can polyiso made for roofing applications be used on walls?
![](https://secure.gravatar.com/avatar/5fe35eda728477271a0c6c9d9196d109?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
I cannot find any non-foil faced polyiso for an exterior retrofit in my local area. Several retailers have polyiso made for roofing application from Altas or Hunter such as Hunter Panels H-Shield. Can these be used for wall applications?
The reason you will not generally find polyiso rigid insulation without foil facings is that it is too water absorptive and will outgas and lose its R-value unless faced with an impermeable membrane. Under a roofing membrane, it will perform OK, but not as well as wall insulation.
However, as wall insulation, foil-faced polyiso board is a near-perfect vapor barrier and one must be very careful about placing a vapor barrier in any wall system, particularly if there is another vapor barrier or vapor-impermeable material installed.
