Can I use EPS foam for vented ceiling?
![](https://secure.gravatar.com/avatar/7ae6679b747bceff77126ea41ddc7e19?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
Recently bought a house with room above trusses that were not finished. I am now finishing them and plan to do a vented ceiling as some of the ceiling is vaulted and shares it’s framing with the roof. I plan on doing continuous vents from the soffit to The ridge. To make the vents and insulate Can I use EPS foam in a “stack of pancakes” method Inside the entire rafter cavity or should I switch to mineral wool before the Sheetrock? Also, would air barrier/vapor retarder such as MemBrain be Required?
Hi user-7620088 (It would be great to get your real name).
I suggest that you start with this article: How to Build an Insulated Cathedral Ceiling.
I believe it will answer your questions and give you many options to consider.
