Can I spray foam the inside skirting of my house?
![](https://secure.gravatar.com/avatar/5f05aa1cd07b7cfa03d39ce589a3b692?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I am trying to keep my water tanks from freezing – my water tanks are under the house. Would the house shift from this? The house is sitting on wood pads.
Are you asking about the insulation causing the ground to thaw? Can you just spray the tanks? People leave large water tanks outside (foamed) all year in Fairbanks. I don't know how it works, but it does.
Mike,
Can you tell us where you live and describe your house a little better?
I'm visualizing a house on wooden piers, with skirting surrounding the piers. Is that what you have?
If so, I don't recommend spending lots of money on spray foam to spray your skirting. The money would be better spent on a concrete foundation. John's advice makes sense: spray the tank, not the skirting.
Do you also have plumbing pipes under your house? Are your pipes freezing?
Live Churchill, Manitoba . The building is raised on wood pads and skirted with exteriors pywood. If I foam the skirting from under the house would that effect the structure with shifting etc.?
Mike,
Do you live in an area with permafrost?
yes permafrost is about 3 ft down .
Mike,
I'm not an expert on permafrost issues, so I suggest you obtain local advice. Perhaps some GBA readers from Fairbanks will provide further comments.
In general, if you insulate around the perimeter of the foundation of a house built over permafrost, the heat from your house will raise the temperature of the soil under your house, leading to the possibility of melting. This may lead to a problem -- for example, uneven settling.
Insulating the tanks with even a foot of foam would require less foam than insulating the skirting, would freeze-protect the tanks better, and suffers no permafrost-foundation issues.
