Can I know the function and operation of duct heating on two channel method?
![](https://secure.gravatar.com/avatar/7c25a15db41d09b697a9aaa7fcce5453?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fh.png&r=g)
Bernard Ho
| Posted in Mechanicals on
The specific and simplest explanation for the duct heating on two channel method..if can, hope can have the picture..Thank you
Ho Y Nam,
I'm not sure what you mean by the "two-channel method." But I am guessing that you are referring to the fact that forced-air heating systems have two separate duct systems: a supply system and a return system.
Briefly, here is how a forced-air heating system works. A furnace has a burner that heats air in a heat-exhanger. A fan distributes the hot air through a duct system. (That's the supply system. We call these ducts the "supply ducts.") And a return-air duct system pulls air from some of the rooms in the building and brings the air back to the furnace to be heated again.
I will attach some illustrations below.
MARTIN HOLLADAY, GBA ADVISOR
I'm very thank you for your answer, that will help me more understand about this heating method
