Can I install 1/4-inch fan-fold board instead of rafter vent chutes?
![](https://secure.gravatar.com/avatar/9a7ecdce741fc29d895c4798c3f7ad9a?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
I live in ohio. zone 5, and was thinking to add blown in insulation to my attic to bring the r value to r39. right now I have existing fiberglass insulation with some blown insulation on top. It’s has partly wood down for some storage which I plan to build the outside up to hold the blown insulation off the walk way. Question I have is I have to install rafter vent chutes from the eve to stop the insulation going into the eve. I was wondering if I buy 1/4in fan fold board which comes in 50ftx4ft . It would be cheaper and easier to install than buying rafter vent chutes and install them to each rafter bay on the sheathing. I was hoping to just nail the fan fold to the under side of the rafter from the eve up the length of the board which would create a vent chute that insulation couldn’t get into the eve
Bob,
You probably don't need the full rafter depth for these ventilation channels. Generally, it's wise to aim for 2-inch-deep channels.
Fan-fold is a little flimsy for this purpose; most people use stiffer material.
Here is a link to an article that discusses all your options in detail: Site-Built Ventilation Baffles for Roofs.
Thank you martin.
