Can cellulose insulation in an attic be re-fluffed?
![](https://secure.gravatar.com/avatar/4e0f065b28dc5b5967891e913316adf2?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fv.png&r=g)
I am installing new light fixtures in the ceiling of a house with cellulose in the attic. As I move around up there, the insulation is being compressed. I assume that this will lessen its effectiveness. What can I do or have done to regain the value of the insulation?
Vern,
Although the R-value of cellulose decreases slightly as it settles or is compressed, the compressed insulation is better at resisting air leakage.
It isn't worth the time it would take to develop a way to fluff your existing insulation. If you want to improve the insulation's R-value, it makes far more sense to simply add more cellulose on top. Cellulose is relatively cheap.
Just smooth it out so there are no thin spots.
