Can an applied veneered cut stone on the exterior of a house in Houston, TX hang over the property line?
r_marron | Posted in Building Code Questions on
Any help appreciated, be it by links, PDFs, response.
Thank you
  1. GBA Editor
    Martin Holladay | | #1
    Rodrigo,
    My first response is simple: "Of course not."
    But I may be wrong. The only answer that matters is the one that will be provided by your local building department.
  2. r_marron | | #2
    Thank you for responding quickly. I will look into that.
    MALCOLM TAYLOR | | #3
    No. Infringment, whether on the ground or aerial, is still infringement. This also applies to roof overhangs, including gutters. Without an easement you can not use a neighbours property. The only exceptions might be infringement onto municipal or common property. Sometimes things like patios and awnings are allowed with licences, but these are generally temporary.
    Even if your municipality for some reason decided to turn a blind eye, you would likely face a civil suit from the neighbouring property owner.
  4. STEPHEN SHEEHY | | #4
    Your question should be to a local lawyer, not GBA.
  5. Expert Member
    Dana Dorsett | | #5
    In a classic case in Seattle a century or so ago, a developer in a zero-setback downtown district built a multi-story brick building 6-8" back from the property line, then waited while a competitor built a similar building directly up against his. After the second building was fully built & occupied, he then then sued to have the offending building removed from his property (which would have been outrageously expensive to do), and ended up bankrupting the competitor.
    Unless you can get a permanent easement from the abutting neighbor in place ahead of time you would be crazy to cross that line.
  6. r_marron | | #6
    All of your responses have been helpful, thank you for your time.
