Cabinet recommendations?
![](https://secure.gravatar.com/avatar/2754f90edca36c8c5a06caf53a8586e2?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
Carfar96
| Posted in Green Products and Materials on
Does any one have any recommendations of formaldehyde free and low/no VOC painted cabinet brands? Thank you!
Carolyn,
You can start by consulting the GBA Product Guide, which lists 8 cabinet makers. Here is the link: Residential Cabinetry.
Barker Cabinets:
http://www.barkercabinets.com/
They offer some finishes or you can get them unfinished and DIY.
I agree the the recommendation for Barker cabinets. A somewhat similar option is Keystone. http://keystonewood.com/ Keystone sells only to professionals, and the kit you get from Keystone isn't quite as fully prepped. With Barker, 100% of the screw holes are pre-drilled. With Keystone, many are, but there still some you have to measure for and drill, and you don't get instructions for every step--they assume you are a pro and know how to put together a cabinet. The things I like about Keystone are that they are a little more flexible in what you can order, and the end panels are inherently reasonably finished looking, or can be truly finished for a smaller up charge.
