Sucking Sound from Radon Pipe
![](https://secure.gravatar.com/avatar/1e743431aa30e57380f14070ec435975?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
Active attic radon fan in place for a couple of years. Normally, can hear a little bit of air moving from gap between concrete slab & foundation wall. Steady, low volume noise. Liquid on gauge has normal differential, 1.4.
New noise coming from pipe about one foot above slab. Sounds a bit like sucking air with a straw as your drinking glass empties. Not quite the same sound, but similar. Also sounds a bit like a bee hive. Pretty loud, can hear it 20 ft away. After a bit, volume dropped some. Any thoughts? Thanks.
Best cut the pipe and have a look.
