Building wrap: under the exterior foam, or over?
![](https://secure.gravatar.com/avatar/ce855b012d170d329fc86129403a2908?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I am building a one story, unvented crawl space, vented attic 1350sqf home in zone 7, Northern MN. Basically going REMOTE. My carpenter and I were looking at the REMOTE manual today, and we noticed Tyvek building wrap was put on the sheathing before the foam was installed. I will have 3 1/2 inches of foam, 2″ resting on top and even with the outside edge of my 2 1/2 inch ICF’s, (both in and out) and 1 1/2 on top of that extending down under the ground level. All 3 1/2″ of foam will extend up to the top of 16″ energy heel trusses with blown cellulose in the attic. I think I read somewhere that some/most builders think the house wrap should be at the window level; I will be having triple pane Marvin outies. I also put 2×6 joists on top of my walls for a wiring chamber, and started sheeting the top of those today. We hope to finish that and start the trusses tomorrow, so we have some time, but not a lot, to make the house wrap decision. Any comments would be appreciated.
Steve,
You should read this article: Where Does the Housewrap Go?
Thanks Martin, good article.
I only used 2.5" foam but used Drainwrap under it. My windows are on the sheathing there where the Drainwrap make the weather resistant barrier. I did "innie windows" and basically have exterior "extension jambs." However, if it is in your budget and you have time, I see no reason why you cannot put a second house wrap layer over the foam.
