Brick wall
![](https://secure.gravatar.com/avatar/5576acb22253d437c1b8dc55790b0052?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I have an old brick wall above ground that can’t be waterproofed from the outside. Wall is three brick wide and let’s moisture through from wicking/ vapor process. Wall had batt insulation directly against brick wall which was creating condensation on insulation resulting in mold. How can I prevent water moisture from building on materials that have potential to create mold. Home is located in PA for so cold winters and hot summers.
Here is an article that may be helpful:
https://www.greenbuildingadvisor.com/article/insulating-old-brick-buildings
