Brick sealer on a wall with exterior insulation
whitenack | Posted in Green Products and Materials on
Hi all,
We are in the final stages of completing our Pretty Good House. We went with (from inside to outside…) 2×6 stud walls filled with damp blown cellulose, 2 layers of 1.5″ polyiso rigid insulation, house wrap, air gap, brick.
The builder is suggesting we use a brick sealer (Siloxane) to help slow/stop the wicking of moisture into the brick.
Is there any problem with this? I could see where it could be a benefit if it truly seals the brick from absorbing water, but I also wonder about it preventing water that finds its way behind the brick from drying out.
  1. whitenack | | #1
    I just realized I omitted the sheeting when talking about our wall construction. We used 5/8" OSB between the 2x6 studs and the polyiso.
    Clay,
    The best way to keep bricks dry is with a high foundation and good roof overhangs.
    Siloxane is sometimes used in a difficult situation, when all else fails -- usually on a poorly designed house with water-entry issues. On a new house, siloxane shouldn't be necessary.
