Bottom line- can I paint interior ceilings formed of roof decking ?
![](https://secure.gravatar.com/avatar/6053d1858b45f61f674ffa30cee6dcac?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I have a 1957 California Ranch house with vaulted beamed ceilings. The ceiling between the beams is formed from the underside of the roof decking/sheathing material. It is a fiber board covered with thin paper skin but you can see raw beveled fiberboard edges between deck sheets. I have attached a photo of the material. Over time the surface of the ceiling has gotten dingy, stained and needs attention. Painting it would be the cheapest, easiest option but I am unsure if the material can stand up to painting?
Perhaps I should mention I also thought about using a peel and stick paintable vinyl wallpaper between the beams but was unsure if the adhesive would adhere to the sheathing without damaging it.
I also considered enclosing the ceiling with plywood, drywall etc… but am concerned about sag, adding that much extra weight to those rib beams…
Deleted
