Bosch vs Mitsubishi Heat Pump opinions?
![](https://secure.gravatar.com/avatar/e5f28a454c1e5390f4411d9b1aa728eb?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Does anyone have any experience or opinions about Bosch vs Mitsubishi heat pumps? I have a relative who is trying to decide between:
Bosch BOVA-60HDN1-M20G 4ton 20 SEER
Mitsubishi P-Series 3.5 ton 18 SEER
The Bosch is marginally more expensive, and the Mitsubishi is a Hyper-Heat model. The house is in coastal Connecticut (Zone 4).
Oh, and the other question is whether hyper-heat is worthwhile in Zone 4 Connecticut, or whether it's overkill.
hi, I'm going through a similar evaluation
https://www.greenbuildingadvisor.com/question/air-conditioner-replacement?discussion=new
Thanks for the tip!
I'm leaning towards this now...
1- Bosch 5 ton condenser Model # BOVA60HDN1M20; 20 SEER; Variable Speed; Two stage; R-410A
1- Bosch 5 ton air handler Model # BVA60WN1M20; 20 SEER; X-13 Motor; 220V; R-410A (To be installed in the attic)
1- Aprilaire filtration system, RE2210 MERV-13, 20x25
1- Aprilaire 8920W thermostat with (1) Aprilaire # RE8053 Surface Mount Sensor
