Bonfiglioli strapping size
![](https://secure.gravatar.com/avatar/74d20fba4c156a434ab147e841ef781b?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
Does anyone know why Bonfiglioli uses 1×3 straping instead of instead of 1×2?
In addition to additional cost, it requires 2 different assemblies: 1 centered for wall studs and 1 offset for plates and corners. The only functional benefit seems to be having additional nailing surface, which might be necessary given need to accommodate 4 mechanical fasteners: insulation to strap, then assembled furring to studs, then drywall to furring, and then trim/cabinetry/pictures on drywall.
Any concern with ripping down Zip-R to strips versus site-assembled?
The only differences I can come up with are assembly is fully adhered, OSB instead of lumber strap, strap has to be same width as insulation, and Polyiso not EPS
If Zip-R, with need for 1 less mechanical fastener, what size to rip strips?
I have read that Zip-R is a practical option when using this method. (I believe Dana made this suggestion.)
P.J.,
The main reasons why Bonfiglioli uses 1x3s, I suspect, is:
1. Most lumberyards don't sell 1x2s, and he didn't want to waste time ripping wide boards down to 2 inches on his tablesaw, and
2. If you use 1x2s, the boards are more likely to split when you install a fastener.
But if you have a ready source of 1x2s, and you can solve the splitting problem, 1x2s might work.
