Blocking airflow in commercial flex duct
![](https://secure.gravatar.com/avatar/97be7d8535776c8f3775d78b5316185d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Hello,
I maintain a commercial hair studio that the tenants are often affected by hot air flow through the diffuser so I stuffed the duct with Roxul safe and sound to stop the air flow. Is this harmful?
The answer is it depends.
If you block 5% of the unit’s air flow no problem.
If you block 50% big problem equipment damage is a real possibility.
Is the bothersome hot air flowing in the heating or cooling modes?
