Block wall for soundproofing?
![](https://secure.gravatar.com/avatar/68b9321504b1a4f11f7132c4753e620d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
I’m taking a space that I can install a block wall on two or 3 sides of the space. My floor is a slab not a post and pier so it can hold the weight. I could fill the block with cement or foam. Will that quiet down the inherant noise in a fairly public space?
Piscina,
The sound transmission class (STC) rating for an 8-inch block wall ranges from 44 to 55. More information here: SOUND TRANSMISSION CLASS RATINGS FOR CONCRETE MASONRY WALLS.
To compare these STC ratings to the ratings of partitions with steel studs or wood studs, see this document: Acoustical Assemblies.
