Better Roof assembly
![](https://secure.gravatar.com/avatar/8f28d96bc40d3043744203cc462b1008?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
hello I am building a house in Las Vegas (CZ-3B).
is it cost effective going to an unvented attic using closed cell
spray foam underneath the roof sheathing for insulation , versus doing a vented attic with a radiant barrier under the roof sheathing with batt insulation on the attic floor?
I assume the unvented attic with be more efficient as the Hvac will be located in the attic, but just not sure if the efficiency is worth the extra costs.
