Best way to insulate old home
![](https://secure.gravatar.com/avatar/dd572ce1e09962fc856030efe6bbd9b5?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ff.png&r=g)
I have an older home built between 1850-1870 and while it has been updated over the years, it is in need of new siding so I am trying to determine the best way to insulate, wrap and seal the house properly. I plan to replace the old siding with LP siding and open to any suggestions and ideas. I have heard many different ideas as to how I should be done so I am hoping to get some clarification. I live in Maryland and I am in Zone 7.
thank you in advance,
Frank
Isn’t Maryland in climate zone 4 or 5?
Similar situation for me. 1880s Victorian covered with aluminum siding.
Most of Maryland is Climate Zone 4A. You can find that info here: https://codes.iccsafe.org/content/IRC2018/chapter-11-re-energy-efficiency
I thought we were 5 as well but a search earlier said its 7. Where should I check for clarification, I may very well be wrong.
Frank
https://www.greenbuildingadvisor.com/article/all-about-climate-zones
https://beta.greenbuildingadvisor.com/app/uploads/sites/default/files/images/DOE_climate_zone_map.preview.jpg
http://bcapcodes.org/code-status/state/maryland/
>"Where should I check for clarification, I may very well be wrong."
https://www.energy.gov/sites/prod/files/2015/10/f27/ba_climate_region_guide_7.3.pdf
http://bcapcodes.org/wp-content/uploads/2012/01/cz-map_maryland.png
Only Garrett county is zone 5- the rest of the state is zone 4.
Hi Frank.
You should try to accomplish a few goals including air sealing and insulating, while making sure that your water-management details are working (water-resistive barrier, flashing at windows, doors, and other penetrations).
There are lots of possibilities, and I'm sure you'll get a bunch of opinions, but it would be helpful for us to know what's behind the existing siding and what is going on inside the walls.
Hello Brian,
I have not yet pulled any existing siding down but from the very few spots that I have been able to see from interior projects, i have found that there are random areas of insulation and studs do need seem to be evenly spaced, there will also be some damage that I will take care of when the siding is down. My main questions are around the specifics around what I should be using. I am willing to spend extra to buy all of the necessary items for the job. I also plan to start on the rear of the house that is roughly 500sq ft. Is fiberglass insulation better than foam board insulation, is Tyvek better than felt paper, is a rain screen needed? I would hate to spend money and realize that I did not get the right materials for my area and application. I am also not sold on LP, I have used Hardie in the past and not committed to either.
Thank you for reaching out,
Frank
