Liquid Flashing with Standard Housewrap
![](https://secure.gravatar.com/avatar/1264e3264c4ded00cea51bc1e3d0d327?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Hi, we are about to flash our windows and narrowed it down to using liquid flashing for windows (Prosoco FastFlash). However, we are using a standard housewrap and I was wondering what is the best way to integrate both? Has anyone done it?
Prosoco recommends installing it with AirDam as in the 1st photo. However, Hammer and Hand recommends installing it with embedded transition strip such as Henry Moistop PF (2nd photo) that would overlap over the housewrap.
Is one way preferred over another? If using Hammer and Hand method, how would you integrate it with housewrap on the top or sides of the window? Has anyone done either install? Thank you.
I've used Prosoco-Tyvek-FlexWrap sequence, following manufacturers installation guides.
