Best practices on window sill attachement
![](https://secure.gravatar.com/avatar/a8d61bdb609310a59f6ebc377823f353?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
What is the best way to attach the sill ? The attached pic is a mock up I’m doing on a 4′ wide window, but I also have 10′ wide window/door openings. On the rough opening I have flashing tape / sill pan. I plan on using vertical grain 1x cedar for my sill.
My initial idea is to lay beads of compatible adhesive and add a few screws w/plugs to hold it down and keep it from bowing out. The sill flashing is Exoseal and not so stretched in the area for the screws.
