Best practices regarding blown-in insulation in a double-stud wall?
![](https://secure.gravatar.com/avatar/a8c920ee9a0dc0d1a4701c5ae313728f?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Martin mentioned in another Q&A that choosing a contractor with experience installing blown-in insulation in a double-stud wall is important because of multiple ways it can go wrong. I am going to build my first dble-stud wall home soon and would like to know what to look for/ask for regarding a proper install. In our area (climate zone 4C) dble-stud walls are not common. I can imagine that getting the proper density might be challenging without discrete stud cavities to pack. Advice?
David,
First of all, I suggest that you read this article: How to Install Cellulose Insulation.
Second, here are some questions to ask your insulation contractor:
1. Have you ever insulated a double-stud wall before? How did that project go?
2. Are you familiar with the dense-pack method? If so, how do you determine that the insulation has achieved the desired density?
3. Have you ever had to insulate a very large cavity -- for example, a triangular attic behind a kneewall? If so, what approach did you use?
The answers you receive to these questions should give you a pretty good idea of whether the contractor knows what he or she is talking about.
Thank you Martin, your answer and that great article answered my questions!
