Best insulation/ vapor barrier/ siding method
![](https://secure.gravatar.com/avatar/730c9ca1edd7d9bb00821a0565e43196?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I have read of numerous methods for insulation/ vapor barrier.
What is best wall construction? I plan to use, from outside to inside- cypress vertical siding, horizontal furring strips, tyvek, 1/2″ plywood, 2×6 studs, spray foam, fiberglass bats, sheetrock/ wood paneling.
House is in Virginia Mountains over basement.
I would like to a see a rigid layer of foam to the out of the shell to help eliminate the thermal bridge of the studs. This, in some cases, can nearly double the R-Value of the wall assembly.
Make sure the foam is super air tight.
You can do away and save the plywood and potentially the Tyvek (although cheap insurance) with a foil or skinned exterior foam.
Make sure the horizontal strapping has some ventilation cuts in it to allow for air movement behind the siding.
