Best exterior veneer for very thick exterior foam sheathing
![](https://secure.gravatar.com/avatar/67d0b2b6989065fbd36c088499508403?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
My wall plans for a new addition now call for 2×4 framing, OSB sheathing, rubberized adhesive membrane and 7 inches of Atlas R board poly iso insulation with 1×4 vertical furring. My original intent was to use metal siding by Firestone. A recent Building Science white paper on cladding attachment through exterior foam raised some potential long term issues with “heavy” siding over 6 inches of foam. My architect is currently recommending the use of light weight aluminum soffit sheathing as the siding. Has anyone done this before? Any better recommendations for a different light weight siding other than vinyl which I don’t like for aesthetic reasons ? I also am not too keen on wood because of the maintenance issues.
Timothy,
One possible solution is to scale back from 7 inches of polyiso to 6 inches of EPS, for two reasons:
1. Recent modeling studies raise questions about the cold-weather performance of polyiso (see In Cold Climates, R-5 Foam Beats R-6).
2. Plenty of builders have successfully installed heavy siding on 6 inches of rigid foam.
For more information that supports the idea that heavy siding can be attached to furring strips screwed through 6 inches of rigid foam, see:
REMOTE: A Manual.
Fastening Furring Strips to a Foam-Sheathed Wall.
