Best choices for vapor barrier for a 1930s built home with dirt floor and partial full height crawl space?
![](https://secure.gravatar.com/avatar/a32b64838882cfb95f8c9ad58af89bb4?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fg.png&r=g)
Looking for best vendor for 10 mil poly ? Also has anyone ever laid down tile backer board as partial rat slab ? The poly alone is going to be a PITA . The house has stacked stone piers with some cmu block. When crawl spaces are difficult like this one , is power venting an option ? I want to keep it sealed , also there is no A/C ducts in crawl space. The project is Zone 5 Western NC.
Green Confusion,
First of all, I suggest that you read this article: Building an Unvented Crawl Space.
One brand of tough polyethylene used for crawl space floors is Tu-Tuf. Here is a link:
Tu-Tuf polyethylene.
You mention "power venting." If you install an exhaust fan, make sure (a) that the fan is not oversized (you want a fan rated at 1 cfm per 50 sq. ft. of crawl space); and (b) that you include a passive source of makeup air from the house above (usually by means of a floor grate). For more information, see the article I linked to in the first sentence of this reply.
