BEopt and Mitsubishi KP24NA/KA24NA
![](https://secure.gravatar.com/avatar/50741af3b2af247913160e3c9ffc4156?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I’m trying to run BEopt against a house design and am not having any luck getting it to work with a Mitsubishi SVZ-KP24NA & SUZ-KA24NAHZ configuration. This is a variable-speed unit but other than the stated COP in the Mitsubishi spec sheets I have no idea what to fill in for the multiple EER, SHR, Capacity Ratio, Fanspeed Ratio, etc.
I tried using the only included variable-speed unit in BEOPT which had ratings much different than the Mitsubishi, and that triggers errors from BEopt when I run the calculations.
Are there any other modeling tools that might be a little more up to date?
Thanks!
EER 12.5
SER 18
https://www.mitsubishitechinfo.ca/sites/default/files/SB_SVZ-KP24NA_SUZ-KA24NAH2.TH_201912.pdf
