Bedroom egress window requirements
![](https://secure.gravatar.com/avatar/6fe7085ce52ab95ae9c678e691a4e0cb?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Do I still need to use an “egress” window? My master “suite” has two entry-exit paths, one through a central hallway and a second that opens into the ‘family room” The family room has an exterior door located immediately to the right as one enters from the master suite.
You also have to look at "light and air" requirements. But yes... you need to be able to exit to an exterior location which is then accessible to a public way (not an enclosed courtyard, for example).
Yes, you need at least one exit directly to the outdoors. It can't go through another room, even a closet or bathroom that are part of a suite. It can be a window or door, as long as they meet size requirements.
Read 2015 IRC R310. & R311. https://up.codes/viewer/general/int_residential_code_2015/chapter/3/building-planning#R310
