Exterior Insulation and Window Replacements
![](https://secure.gravatar.com/avatar/c667ec0823b1c467dcc7a3bebd7635db?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
Hello!
I am currently working on an exterior renovation of a kitchen addition. The kitchen has a large Bay window that I will be replacing. I am also planning on replacing the existing lap siding and adding 2”of Rockwool insulation to the outside of the sheathing followed by strapping and James Hardie lap siding.
The bay window I have quoted has 6” side jambs which I am told are fairly standard. However, with the addition of the exterior insulation I am worried that 6” jambs will not be deep enough to allow the siding to butt into it correctly (1/2” drywall + 3.5” stud-wall + 1/2” sheathing + 2” Rockwool + 1/2”strapping + 1/2” lap siding = approx. 7.5”).
Should I be ordering a bay window with a deeper jamb? Or is there a good way to detail where the bay window and the siding/insulation meet that I am not thinking of?
Rob
