Bathroom fan location
![](https://secure.gravatar.com/avatar/5c208b912a8db9dfff9c5361361a0d1d?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
My upstairs bathroom has a vaulted ceiling, parallel to the roof. There is a 18 inch cavity where I will install fluffy insulation and have an air gap below the sheathing for ventilation.
I am wondering about the bath fan. I’m not too inclined to drop the ceiling in the bathroom although it is an option if need be. I have read here that it may be a bad idea to have the fan installed in the vaulted ceiling.
Would putting the fan in the exterior wall be a better? Or can I do an impeccable air sealing job and it will be fine in the vaulted cavity? Or is dropping the ceiling far and away the best option?
Joe,
Rather than interfere with the roof or exterior wall, consider dropping a bulkhead. Design it to look good architecturally and perhaps incorporate some lights too. That removes all the problems with air-sealing and insulation.
