Basement Insulation Detailing
Wytas | Posted in General Questions on
Hello,
I am looking to finish my basement in climate zone 5A (Massachusetts) and get the insulation detailing correct.
1. I have glue foil faced EPS foam board to the foundation walls and taped the seams. Then framed a 2×4 wall infront of the EPS. Plan is to then fill those bays with unfaced R-15. Does this method seem acceptable?
2. In another part of the basement where there is a 4′ foundation wall (walk-out basement) then 2×6 framing on top of it. They have put unfaced insulation in the bays with 6mil poly stapled to studs. I have framed a full height wall infront of the 4′ wall so I wouldn’t see it in the finish. My thought would be to remove the 6mil poly and put kraft faced r-15 in the bay instead of sandwiching the poly in between two unfaced batts. On the 4′ foundation wall I have glued foil faced EPS to that and would think to use unfaced there (same wall assembly as described above)
Picture 1 is the first scenario
Picture 2 is the second. You can see what I am trying to describe on the left side of the image.
Any feed back on these two scenarios is greatly appreciated.
  1. Malcolm_Taylor | | #1
    Wytas,
    Both your plans sound good. I'm not sure it makes much difference whether you use faced or un-faced batts in the double wall.
    1. Wytas | | #2
      Thank you for getting back to me on this,
      Rereading my O.P, not sure if it was that clear on scenario 2. For the 2x6 wall (double wall), could I leave the unfaced in the bay, remove the poly and put faced insulation in the new framed 2x4 wall from floor to ceiling?
      -Or will the faced insulation and faced EPS create a double moisture barrier issue for the 4' section of foundation wall.
      - Or does it not matter much being only 4' having the faced fiberglass and EPS.
      1. Malcolm_Taylor | | #3
        Wytas,
        Kraft faced batts are a class 2 vapour retarder. You can safely use them on both the bottom and top of the wall.
  2. Wytas | | #4
    So then would it safe to use faced insulation in the 2x4 wall pictured in image 1? What class vapor retarder is the faced EPS?
    1. Malcolm_Taylor | | #5
      The faced EPS is a class one. It's what is still called a vapour-barrier in our code.
      I wouldn't use faced-insulation in the wall in image 1. I don't think it would do much harm, but the wall is safer without it. The wall in image 2 has some drying to the outside, and a class two vapour-retarder will help reduce the amount of moisture that gets into the wall.
  3. Wytas | | #6
    Thank you for taking the time to answer my questions.
    1. Malcolm_Taylor | | #7
      Good luck with your project.
