Basement insulation
![](https://secure.gravatar.com/avatar/1264e3264c4ded00cea51bc1e3d0d327?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Hello, after reading through many articles here on GreenBuildingAdvisor, we are considering installing rigid foam on the interior wall of our basement (this is new construction). However, I just noticed that our plumber run his lines tight on the concrete walls so we can’t slip the rigid foam boards under. Is there a way to detail this somehow with rigid foam?
Do we even need rigid foam on the interior walls? When we waterproofed during the construction, we installed R-10 insulation on the exterior of the basement walls. We are in NY, zone 4.
thank you,
Lana
