Insulation and Smart Vapor Retarder for Unfinished Basement
![](https://secure.gravatar.com/avatar/4143ca55ab7606a20acd365cc07b022e?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I am a new New Construction builder and wondering what would be a good option for basement wall insulation in an unfinished basement. Most of the homes that I will be starting to build will all have unfinished basements with plans for the clients to finish at a later date. I hate the “builder grade” 4′ down insulation that everyone seems to use. This obviously still needs to be cost effective and available! Maybe a foam board glued to the wall with a smart barrier taped to the sub slab insulation. Then running a 24″ strip of that smart barrier under the mud sill before it is attached to the top of the wall. This way we have continuous all the way around?
Bump!
https://www.buildingscience.com/documents/bareports/ba-0309-renovating-your-basment/view
For the mud sill, you want to use acoustical sealant…use the search button for mud sill.
