Basement corner frame around electrical panel question
![](https://secure.gravatar.com/avatar/60958aa27a98d7ce096fafd6c5f7962b?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
So I’m looking to finish a space in my basement. The space has an electrical panel near a corner of the concrete walls. I am putting up 2″ rigid foam on the concrete and that will leave me 2 1/4 inches to the edge of the panel. What is the best way to frame that corner? If the panel has to be moved then that would also require extending about a dozen wires coming out of it that run to various locations in the house so it would be nice if I didn’t have to move the panel.
Wade,
This is a classic example of a dilemma that occurs all the time when insulating basement walls. There are two possible solutions: the easy and cheap solution (in your case, leaving the electrical panel where it is) and the difficult and expensive solution (in your case, hiring an electrician to move your electrical panel a few inches inward, to allow spray foam or rigid foam to be installed behind the electrical panel).
Similar dilemmas occur with basement stairs that are located tight to the foundation wall.
Easy-and-cheap will never perform as well as difficult-and-expensive, of course, because the easy and cheap solution will leave a big thermal hole in your insulation. Only you can decide which way to proceed.
If you decide to go the easy-and-cheap route, you can install wood trim around your electrical panel.
