Basement bathroom exhaust duct loop
![](https://www.greenbuildingadvisor.com/app/uploads/assets/avatars/26979-avatar-1565047362-100x100.png)
I need to install a bathroom exhaust fan in my basement. I’m near the steel support beam (5 feet away) that supports the middle of the I- joists. The I joists are continuous over the support beams.
I’m concerned about putting a 3.5 inch hole through the I joists. I’m equally concerned amount putting a p- trap in the exhaust duct. See the attached drawing.
John
John,
Th installation manual of whatever I-joists you used will have instruction for where and how big holes in the webs can be. They are all available online. My bet is you will be fine with a 3.5" hole.
