Baseboard Vent for Older House
![](https://secure.gravatar.com/avatar/8c9da94837c1440f9ca279837c2fc975?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
Hello, I live in an older home with my heating ducts coming out of the walls in several rooms. I was told I don’t have the right supply covers on the walls and baseboards which is one reason the rooms are not getting enough heat. Which kind of vent/diffuser cover should I get? The size is unusual as well: 15 in by 12 in
That size is typical in older homes that had a gravity heating system.
Thank you for your reply. I will see if I can find a modern version of a gravity baseboard register.
