Attaching Gable Stud to Gable Rafters
slugboy6000 | Posted in General Questions on
When I built my cabin (home) about 10 years ago, I face nailed through the inside of the gable end rafters into the gable end studs which I didn’t notch (see images below).
With a bit more experience, I wonder if that was sufficient.
I was assuming the gable end walls weren’t load bearing but there are significant snow loads (60-70psf) on the 12:12 slate roof – it’s heavy.
Do you think it’s worth beefing this up a bit somehow?
    Michael Maines | | #1
    While unconventional, I don't see a need to change anything. The studs will easily accommodate the additional load of slate.
  2. Malcolm_Taylor | | #2
    slugboy6000,
    If it is going to worry you, throw another couple of nails into each one.
  3. freyr_design | | #3
    If it is bearing on your top plate then the load is the exact same as the rest of your rafters (though, maybe a touch more considering eave). I would be more concerned with your rafter ties and making sure they are appropriately fastened than with your gable rafter, though with a 12/12 there is not a ton of outward thrust. The way you framed it I would be more concerned with the shear of the structure, as the way it’s framed there is not edge nailing. This is very important with sheathing, I have not designed a structure with board sheathing so I dont know how important that is, but I imagine it would help.
    Edit: also looking at it again since it is not balloon framed the edge nailing doesn’t matter as much
  4. slugboy6000 | | #4
    Okay, thank you for the replies - I really appreciate being able to get advice from the pros sometimes.
