Attached garage ventilation
![](https://secure.gravatar.com/avatar/8e2c1240717a0f71fbe9a56b2a5bf3a0?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
I am looking for some guidance for venting an attached garage of exhaust fumes when coming and going. I have AirCycler’s Garage Vent module. Now, all I need is to pair it with a fan of some sort. The garage is roughly 24x24x10. Any recommendations on brand, CFM, location?
I am considering a simple Broan through the wall exhaust fan that will do around 300 CFM at 6 sones, but that is designed for interior use. While the garage is protected from the elements, there are the issues of temperature, humidity and critters.
Norman
CZ 3A
Norman,
I think you're on the right track. Tamarack offers two models of exhaust fans designed for garages; one is rated at 235 cfm, and the other one is rated at 416 cfm. Here is the link: Tamarack Garage Ventilation Fans.
You might also want to read this GBA article: Don’t Let Your Garage Make You Sick.
