What to Expect from an Air-Source Heat Pump Annual Maintenance Appointment
![](https://www.greenbuildingadvisor.com/app/uploads/assets/avatars/25364-avatar-1582139610-100x100.png)
Hi good folks,
I’ve got my first annual maintenance appointment scheduled for my Mitsubishi heat pumps and wonder what I should expect. What happens when they do the annual maintenance?
I’ve already cleaned the fans. Do they test the lines for leaks? What should I look out for when the technician shows up?
thank you, Kris
Kris,
Is this a split or conventional forced air unit?
Good morning,
I have 2 x MSZ-FH06NA upstairs and 1 x MFZ—KJ09NA downstairs, ductless mini splits. Each indoor unit has its own outdoor unit, in a one to one configuration. So, outdoors there are 2 x MUZ-FH06NA and 1 x MUFZ-KJ09NAHZ-U1.
The company says the maintenance will take 2-3 hours.
Thanks, Kris
Kris,
This article may be helpful (but possibly too late for your maintenance visit): https://www.greenbuildingadvisor.com/article/how-to-prevent-condensate-leaks-from-ductless-heat-pumps.
