Are there any pre-designed house plans that feature ICF walls & SIP roofs?
![](https://secure.gravatar.com/avatar/5730210db14ba879cf3601ecc4361563?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
Looking to see if there are any plans out there that feature ICF walls and SIP roofs? Or is this something that has to custom designed by an architect?
I am currently designing my own ICF house and I am considering using SIP's for the roof structure.
I never found pre-designed ICF house plans. They would have to be tailored based on the ICF block used in order to simplify execution. That should pretty much answer the last part of the question as well.
Where about are you located?
