Are MERV ratings per-pass through filter or cumulative?
![](https://secure.gravatar.com/avatar/ddbf893a6c4b0f76d8f2f6f18feec527?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
A MERV13 filter removes greater than 50% of particles sized 0.3 to 1.0um per the chart in the article below. If a particle in this range passes the first time greater than 50% should have been removed. On a second pass, will it be 50% of the remainder? This would imply after the air has been cycled through at least twice a MERV13 h as removed at least 75%, correct?
https://www.greenbuildingadvisor.com/article/understanding-filter-ratings-merv-fpr-and-mpr
