Are leaks in a structure…
ideas123 | Posted in Plans Review on
Checking for leaks? is the Green’s leakage decreased in homes, now that it has gone green? Or, is it basically the same / near or = to studies (in normal construction techniques)?
  1. GBA Editor
    Martin Holladay | | #1
    I don't understand your question. But I'll make a guess.
    If you are asking, "Should a green home have an air leakage rate that is less than the air leakage rate in a typical home?" -- the answer is Yes.
  2. srenia | | #2
    oddly phrased quetion. Is a truly green building materials able to air seal as well as modern materials in construction? Just guessing that's the question.
    Matters what you consider green materials. When I look at plastics and other oil based products the home actually might be the one place that having a material that is hard to throw away be wise.
    Dana Dorsett | | #3
    The definition of "normal construction techniques" needs to be spelled out in detail. Many builders (usually in colder climates) were constructing houses that would test under 3ACH/50 even before it was mandated by code under IRC 2012. Many other builder normally built houses 3-5x that leaky prior to IRC 2012, and still struggle with it.
    At 3ACH/50 a lot of comfort issues (such as overly dry indoor air in winter) go away, but it also makes active ventilation (particularly kitchen & bath exhaust ventilation) rise in importance for keeping indoor air quality high.
    That's not to say leakier houses always have higher indoor air quality- they don't. A lot depends on just where the infiltration paths are.
