Anyone have experience with Aeroseal duct sealing?
![](https://images.greenbuildingadvisor.com/app/uploads/2018/07/24184344/picture-7374.jpg)
I’m considering developing a magazine article on Aeroseal duct sealing. This is a process where registers and diffusers are sealed with plastic and a vinyl based sealant is blown into the ducts. The sealant collects around leaks until they are ultimately closed off. The big advantage is it can seal ducts that are inaccessible for conventional sealing methods.
Here’s more:
http://www.aeroseal.com
Patrick McCombe
Fine Homebuilding Magazine
Hope this reply isn't too obvious. The 'This Old House Hour' TV program did a feature on a system like that (may have been the same) in last year or so. It was in the 2nd half-hour where they do the 3 short features.
Thanks Mark. They have many previously-run Ask This Old House shows on the their website. I'll look for it. It may even be on my DVR. There's at least a dozen I haven't seen on there.
Patrick, there is a link to the episode on aeroseal's website.
Thanks Donald. I just watched the episode. What I learned after my initial inquiry is that most duct systems are undersized, especially return ducts. The leakage is only part of the problem typically. When you seal the ducts you can starve the furnace for air.
