Opinions on Fiberglass Rebar
I couldn’t find where this has received much discussion on GBA. It seems similarly green as metal rebar and to have better physical properties for some purposes and lower cost. Is it difficult to work with? I have an idea for a specific use for it because of its insulating charateristics. Please, has anybody used this?
Be careful, some physical properties are worse, which can cause design issues. Also look at stainless steel - it's thermally much better than steel. Or steel fibers.
Thanks Jon R!
I may use both. I don't understand how you work with fiberglass rebar when you have to raise it to 200C to bend it? Anyway, I think I may have a special use for fiberglass rebar because of it's insulating characteristics. I will post a detail with that in it soon. As soon as I get my wind back. I have been on a roll today...
It looks like you factory order the bends you need. Or order the special type that can be heated and field bent.
Thanks Tim
I haven't used GFRP personally, but I did a bit of research on it a while back. I believe the main downfall is that it stretches somewhere around 4-5 times as much as grade 60 rebar, though I'm sure that amount is variable. That leads to wider cracks, more displacement, and as a result lower durability in the long run, so you have to use a higher % area of GFRP, congesting the volume, etc..
Tyler Ley has a good set of videos on it, search for his channel on youtube, it's full of high and low level concrete info.
Thanks Kyle
