Alternatives to air sealing around windows & doors
draperson | Posted in Energy Efficiency and Durability on
Happy Holidays, everyone.
In the new year I’ll be replacing all door and trim. Before installing the new trim, I’d like to air seal around the doors/windows. I’ve read that spray foam works well for this. But I’m wondering if there are alternatives to spray foam for this application. My reasoning is indoor air quality / exposure to chemicals. I don’t have anything to site to show that canned spray foam is bad, but ideally I’d find a non-toxic solution.
Thanks!
Matt
    Michael Maines | | #1
    Matt, I don't have first hand experience with it but from what I've heard this is a decent alternative to spray foam: http://www.smallplanetsupply.us/hannoband-3e-sealant-tape-64-6-15-23ft-per-roll/. Or if you tape both the interior and exterior so they're airtight, you could stuff mineral wool or other fibrous insulation in the construction gap.
    MALCOLM TAYLOR | | #2
    Matt,
    As Michael said, tape works well - or caulking if the space between the jambs and the rough framing isn't too wide. Either of these provide a very good air-seal. You may want to re-think your use of spray foam and use it to fill the space behind the tape or caulking. With a good air-seal there isn't much chance of any of the chemicals you are worried about off-gassing into the interior.
  3. GBA Editor
    Martin Holladay | | #3
    Matt,
    I agree with Michael and Malcolm. (What is this, a convention of people whose names begin with M?)
    Another source of supply for high-quality tapes is 475 High-Performance Building Supply.
  4. Expert Member
    Michael Maines | | #4
    To be clear, the tape I linked to comes compressed and expands to fill the cavity after installation. This is 475's version: https://foursevenfive.com/product/contega-fiden-exo/.
  5. draperson | | #5
    thank you everyone! You (and this site) have been unbelievable resources.
  6. Jon_R | | #6
    As far as I know, the movement capability of canned spray foam is near zero. So when that 1/16" gap later opens up to 1/8", you have an air leak.
