Allison Bailes Discusses How to Retrofit Forced Air HVAC With High Merv Filtration
![](https://secure.gravatar.com/avatar/685834e9d8830d0c5cca46ed184f5eaf?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Here is an excellent article from author Allison Bailes which I found in The Journal of Light Construction (April 2021 edition) about how to retrofit forced-air HVAC with higher-Merv filtration. Apparently it’s not just a question of switching out a cheap filter for a better one, and the higher resistance from the Merv filter may require an HVAC system redesign.
https://www.jlconline.com/how-to/hvac/retrofitting-forced-air-hvac-with-high-merv-filtration_o
